Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
umm looks pretty scary outside, ive covered her all up. hope the plastic dont leak :down:
saw a couple of holes in your covers :P , hope it does hold off. Underside looks real nice. Awesome job boys.
Shan turns out the D-max aus is fake and no one should buy it!
its actually racespec thats using a D-max business card and sources parts actually not from D-max but cheap shit like DMD
shan i sent you a email with .zip fileE!!!!! answer me bish!!! i need it done mate to get your overfenders mate!!!
oh and about the front bar for the R32??
found my so called setup for the time being!
looks like im getting d-max overfenders too black man! edit: shan :P
anyone who wants D-max gear should contact me directly!
Edited by Redsuns88
that lip is f**king epic.
how'd the 180 go?
taR
180 was good - just the turbo proved painful - we were setting it up but then realised that we didnt have an adapter for the oil lines, so shes not going to be ready until next weekk
and yeh - that lip kit is amazing, hint hint
so 1 more week of RB goodness eh tristan. I can't see any of those pics cus work comp is being gay :banana:
Greasy roads on the way to work this morning were good fun :domokun:
lol tas, that car is sporting mad Do-Luck front sides n rear... I'm not using the front cos I prefer my front bar to it, lot more aggro. but yeah uleh, hook me up with dmax's i'll have a look at your stuff tonight.
I threw up on my keyboard and I blame you..Now I'll have to eat breakfast all over again...
+1 :domokun:
just grab a spoon and eat it off the keyboard.
I solve problems.
Thanks . . . that actually works
finally got the underneath fully seem sealed and 2k primed this morning. tomorrow i will sand it back lighty and spray the black (plz not look like nissan stnd black :domokun: ) lol, then ill put some deadner in the arches and through the tunnel.
mmm white goodness, and a sneak preview of how stealth the welded bolt on mounts look (i started off neat seem sealing then started to seal like josh and his sunroof) but still looks the part. no rust for DAVE
yay
peace out.
that's not stealth, that looks like you cut a bit of your floor out and welded in a plate. then took an enema and around where it was welded you had a fluid, bubbly stream of shit to line it. then you painted over it to cover it up.
you were close but no cigar. there is a plate either side welded to the floor plan. and as i said i seem sealed it josh stylez.
can you tell now.
glad i did the underside, got a few runs, needa tweek my gun abit. its good that its underneath but still it could be better.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
