Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
all i can say is that i have 18x10 +12 and they barely fit!
Ah k
http://www.1010tires.com/WheelOffsetCalculator.asp
You can get the specs of your current wheels and compare them to the specs of the wheels you are looking at buying, to get an idea of where they sit
Yeah I cant remember what o/s my current rims are so Ill have to wait till I get home
18 x 10.5 +22 will sit a little further in. Should fit with a little bit of work. Check out the Offset threads in the cosmetic forum. Will give you an idea of what will fit and what won't.
Yeah Im hoping that with a little help from my old mate "Mr adjustable camber arm" we will squeeze em in :)
:rofl:
tim you need to post more
Yeah.....I'm a bit slow...some of us have to work instead of post-whoreing..... :)
f**k you Timmeh, im kicking you in the nuts next time we meet
Bahaha that's the first laugh I've had in relation to that show! Your place or mine :(
Yeah Im hoping that with a little help from my old mate "Mr adjustable camber arm" we will squeeze em in :(
Increasing camber at the rear...in a rwd car for the sake of fitting bigger wheels seems a little counterproductive to me!
Bahaha that's the first laugh I've had in relation to that show! Your place or mine :)
mofo
[ ] News worthy.
[X] Lawn bowls sucks
I went once on a Sunday arvo, got blind and had a great time . . .
Buuut without beer and sl*ts, your right, it does suck :)
    • Today, I'm a Breville BES920 tech, new triac board and new 3x way solenoid. Had overheating issues, home RCD tripping when it got warm, and the boiler stayed on when the machine was shut off. Also, usually 3x way solenoid chatter, this is the 3rd time I'm replacing it. Mind you, this machine is 9 year old and send it every day doing at minimum 3x double shots. When the in laws come over to took after my daughter, it will easily see 6x double shots in a single day. Tried to be somewhat compliant, crimped and then used a screw connector over the top. Would have preferred to use heat shrinks.   After all that, turns out all the overheating has damaged the o-rings to the steam tap as well. Ordered new ones, coming soon.
    • Still got it- First time checking sau in a while ahhaha
    • I don't know about that. I can hoon my R32 around - hard launches, high lateral Gs - with <<1/4 tank without any such shenanigans. This with the previous 040 and the current GSS342. I would suspect a fuel line problem. One of the hoses associated with the top of the tank perhaps.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
