Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
You lowball worse than r31 owners. Even worse than Dave :D
Only got 1 and it is nicht for sale
where?
So is the 31 ute being replaced by a c210?
on boost man - ill find it
i secretly want it - has a tyre rack n shit man, looks mint
mmm interested.
I'll get my chromies back off colin and do swaps
Already offered them to him. He said he'll need some pics to see if they are sik enuf.
Seriously though. Going to need to buy a trailer for the 31 as it isn't getting regoed anymore. Can't afford to rego + insure 2 cars so going to keep the 31 off the road and get a bike for daily duties n keep the GTR at home. 31 would be too much hassle on the road with a minispool and 15x10s on it anyway lol.
If I can sell it, and if he still has the c210 for sale...
Otherwise it will get replaced by something else old skool and cool. Regardless, I decided I want something different from 31
They are fullee sik
As long as I get to borrow the trailer for track days all good :D
It looks pretty decent for the price
Weaksauce
I bag SRs cause I know you guys like em ldo. Driven later modeled ones and they didn't feel laggy to me. I haven't driven many other v8s other than dads xr8 and a couple of dirty commodores but they didn't feel that much different. Dad's is a quad cam 32 valve v8 and it's a bit weird. It never feels like it's really going until you're up around 3500-4000rpm which I think is weird for an 8 but it still pulls hard.
I think the positives outweigh the negatives for the LS1 it's a pity they've never put it in a decent car. Opinions differ on this point obviously but meh.
They got shoved in the elfin streamliner and ms8....even then acceleration for the car was shithouse. 0-100 in around 5secs for a car weighing under 1 tonne :D Shit motor mang, no love for ls1's here, lol.
IF (and I stress the IF) I was going to put a 4 banger into something, it would either be an SR or FJ.
FJ's FTW!!!
should have kept it...
+1 million dollars (holds pinky to lip)
well, next weekend is german club weekend. sat night. germaning it up. be there, or i will have you killed
this weekend.... nuttin
so its on? I am there.
Würste und Bier! FTW!
I have a job interview on Tuesday morning, so fingers crossed peoples!
Good luck!
Just found mice nest in my switchroom... that really f**k my day.
Cool, where at / what sort of job?
Apprentice mechanic at Mitchelton (so I'll have to have a chat to ol' Nick* about it :) )
Thanks Brandon!
*...need to know the history of Mitchelton to even get that... I don't know why I bother sometimes haha
Haha, yeah, i was thinking WTF?
good luck mang :)
HAHAHAHAHA YES!
Good luck mang!
P.O.R.N.
Bud that's not porn, that's pure all out shithot orgasm!!!!!!
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
