g'day
you know how something really simple suddenly takes all time available?
So I need four screws, I think they are machine screws. I don't know the dimensions,
can only carry into the shop the part that contains the embedded threads, that they
would screw into .. :)
I've tried jaycar - they have a range, but not up to the dia I want.
I've tried bunnings, and the ones they sell don't seem to quite work..
I'm trying the ones that bolted on my diffuser, and they are close but not right..
so now I'm stuck! where else can I try around sydney before hitting up mail order places
and buying all kinds hoping for a match!
https://www.sau.com.au/forums/topic/261427-machine-screws/
Do you have a "bolt bloke" or fastener shop nearby?
Should be one within a suburb or 2 i'd imagine (i'm in melb)
googled http://au.vicdir.com/dir/w142356s28148
41 entries
thanks!
"bolt bloke" is a new one for me!
I'll start with Coventry Fasteners, they have branches all over.
the problem is finding someone who will want to take a look at it ..
the profit margin on selling 4 bolts to a guy who doesn't know which one he wants is deeply -ve !
https://www.sau.com.au/forums/topic/261427-machine-screws/#findComment-4481436
Yeah proper bolt shops are so much better than hardware shops.
For next tme, get yourself a thread gauge.
Eg
http://www.irwin.com/irwin/consumer/jhtml/...IrwinProd100450
This will tell you what pitch etc the bolt thread is. Nissan appear to love non standard 1.25mm pitch bolts for all sorts of stuff.
A 'machine bolt' is simply a bolt with the thread all the way to the head. Sometimes they have cup heads on them (for allen keys) sometimes hex heads. Mostly they have a higher strength than normal bolts.
https://www.sau.com.au/forums/topic/261427-machine-screws/#findComment-4482126
  • 4 weeks later...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
