Hey all,i have a nasty noise,in neutril no noise,i drive off in first change to second and get a horrible whirring grinding sound,can feel it in clutch pedal,any idears taa. :P
Do you have the noise in second only, or is it with the second gear onwards?
You may have lunched second gear.
Do you give the car shit often?
Did you have a major miss going into second?
A few more details would help us give you a better opinion.
https://www.sau.com.au/forums/topic/262005-nasty-noise/#findComment-4489621
I'm old,and the 33 is my daily drive.When i depress the cluch i can feel and hear the noise,car drives fine and gear changes are the same,i really hope it's the
the cluch,going to mechanics on monday. :D
If you put your foot into the clutch and end up with a whirring noise, it'll more than likely be the throwout bearing. But this doesn't explain the second gear anomaly.
I hope it all turns out well for you, but keep us posted of the prognosis.
https://www.sau.com.au/forums/topic/262005-nasty-noise/#findComment-4490285
i had a nasty noise for a little while, lol
put some soapy water into the window-washer bottle, but no it was radiator overflow lol
ended up with soap burning on the turbo shaft lol
all burnt out now tho :D
and goes better then ever (as proved on this weeks tune) !!!!
https://www.sau.com.au/forums/topic/262005-nasty-noise/#findComment-4490292
I sure will,clutch seems perfect,exedey sports tuff performance,had it for 5 years,plenty of mods,let daughter drive her around the block,she had heaps of fun,loves 2nd gear,cheeky little bugger.Been testing and seems to be thrust race bearing,wonder if she will cough up some of the repair costs,doud't it shes only 25 reckons it was due to old age tee hee,oh well shit happens,still love my 33. :)
https://www.sau.com.au/forums/topic/262005-nasty-noise/#findComment-4490830
I sure will,clutch seems perfect,exedey sports tuff performance,had it for 5 years,plenty of mods,let daughter drive her around the block,she had heaps of fun,loves 2nd gear,cheeky little bugger.Been testing and seems to be thrust race bearing,wonder if she will cough up some of the repair costs,doud't it shes only 25 reckons it was due to old age tee hee,oh well shit happens,still love my 33. :O
I think I have a similar problem to you Humbla. I just put the Redline Lightweight Shockproof Gear Oil in my R34 GTT.
I've been having a grinding noise when dropping down gears at higher revs eg. 60km/h into 2nd makes a grind, 110 into 4th grinds, 3rd grinds when I shift up from 2nd at higher revs...
I changed gear box oil to see if the problem would go away but it hasn't :S I think it may be clutch related though as the grind can be felt through the clutch pedal when releasing it and the gear engages. You can also kinda feel it in the gear knob as well when you go into the gears. Only happens at higher revs...
Could it be the clutch or thrust bearing??
Any help would be awesome!!
https://www.sau.com.au/forums/topic/262005-nasty-noise/#findComment-4505993
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
