check if the $195 tint has a lifetime warranty on it man, that sounds pretty cheap could be good u never know. oh thats not meant to be nexus, but NOVUS, theres one in gravatt/ nathan area but i got mine down the coast. the tint i got is really dark black, the bad thing is its quite dark from the inside as well!
https://www.sau.com.au/forums/topic/26207-tint/#findComment-555678
