Hi guys, long time reader here first time poster
I've got a r32 gts25 sedan that i've sold my 20det setup (284rwhp if anyone cares) to build a RB30det, so far i've got a garret truck turbo, similar size to 3540, rb30e bottom end and r32 25de head, gtr valve springs, oil pump collar, just buying up the bits as i see them basically
I've also aquired a set of 26dett pistons, I've tried searching and haven't found a definite answer to if i can use them or how much work is required? i have a set of 30e pistons to which i'll use if the 26's arent any good, basically what i'm asking is  a) how hard are the 26 pistons to fit, and b) is it worth it?
thanks in advance guys. I'm sure i'll have many more questions as the build progresses
Cheers :P
https://www.sau.com.au/forums/topic/262171-rb30-gtr-pistons/
Pretty sure you have to use RB30 pistons as their pin heights etc are to suit RB30 rods & crank..
cheers for the reply, so i cant use 30 rods with 26 pistons? i havent had a chance to measure anything up yet, was trying to avoid wasting my time if people already knew the answers haha
might have to take them into work and whip up some drawings to see if its a suitable option,
Not sure on the exact differences, I'm using RB30 spec forged pistons. You might find that with 26 pistons on 30 rods on a 30 crank that you could be smashing pistons into valves.. need an experienced RB builder to answer that :P
cheers guys, turns out one of them is poked anyway so ill prob just stick with the 30 pistons, on the subject of 30 pistons, i've got a set that i had ultrasonically cleaned, when they came back they had lots of pitting in the top of the piston, im assuming its just bad casting/ has anyone else had a set that were the same? i tried to take a pic but it wont pick up the detail- aka budget camera
That pitting is probably from detonation..
I was hoping that wasn't the case but had my suspicions, picking up another motor tomorrow hopefully the pistons in that one are better, first motor had a bent crank (god knows how) so i had to buy a whole new motor to get a new crank, what a mission just to get more power!
Bent cranks are quite common in i6 engines.. just make sure you get all your clearances checked and machine appropriately.
it had about 0.3 bend in it, decided to try another as its cheaper to get a new one than grind, bit of a gamble to but its a low k's engine so should be ok
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
