Hay
I just had a dyno done to me car it is putting 183rwks i was advised by someone that i should upgrade the oil pump, he reckons that that kind of power i should upgrade i want to put a boost T on aswell to push it to 200rwks, is this true about the oil pump
cheers
https://www.sau.com.au/forums/topic/262212-oil-pump/
I'm only pushing 170RWKW's in my RB20 and I just did a big end bearing up at wakefield due to oil starvation. In saying that I was bouncing of 7500 rev limiter (maybe not bouncing but it was a drift day) and had the car being thrown around fairly violently.
So unless you are belting your car side to side, and redlining it, you don't have much to worry about, But i would do it if you were building your motor :)
https://www.sau.com.au/forums/topic/262212-oil-pump/#findComment-4492452
Yes - on the proviso you have done the rest of the mods.
183 rwkw in a GTS-t is very good so I suspect you have a few mods already. FMIC, Zorst, Turbs, Puter etc....If you want to push 200rwkws - safe not sorry. Spend now and save later. Would you risk an engine rebuild?
https://www.sau.com.au/forums/topic/262212-oil-pump/#findComment-4498352
Its an 94 r33 gtst This is My first nissan skyline so i am not sure on what mods i need to do so it does not blow my engine and to get more power
Ok, as its your first skyline ill be very blunt;
-Changing oil pumps in a GTST is a waste of time with that power level, or if its working fine
-You will break the oil pump if you bounce off the redline time and time again
-Always warm up before using more than 30% throttle on cold start
-Always cool down (fit a turbo timer if you're a leadfoot)
-Before adding power, sort out suspension and a short shifter for the gearbox
-Once you've got it sorted suspension wise look for more power
Powerwise;
-FMIC (forum sponsors)
-EBC (forum sponsors)
-HKS GTRS kit (forum sponsors)
-ECU, ideally one that uses MAP vs TPS for mapping (forum sponsors)
-Quality exhaust including highflow cat, good dump pipe (forum sponsors)
EDIT: If you need any further clarification, call a few workshops and get quotes for "just a new oil pump fitted" :laugh:
https://www.sau.com.au/forums/topic/262212-oil-pump/#findComment-4502476
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
