Hey everyone, just thought i would post my wheels up, thinking of a change
They are SSR integal GT1's, not sure of the offset, fit perfect on my R32 GTS-T with rolled guards, also not sure of the widths, i think the fronts are 8-8.5's and the rears are 9-9.5. all i know is the rear is wider lol. If anyone can help me find out the widths and offset it would be a great help.
tires arent the best, rear are just legal and fronts have the inside warn out cause of camber. Wheels have some slight gutter rash.
Looking at around $2000, I'm in the Brisbane area
If i have left anything out please let me know
Thanks Pete
Edited by PetieR32
https://www.sau.com.au/forums/topic/262279-ssr-wheels/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
