Hi all i am regretfully selling my beloved 1994 R33 GTST 5-speed Manual. I have owned the car for the last 5 years and has served me well.I own 2 other cars and rearly drive this one any more. I am the first owner in Australia. Brought stock standed with 60k. Now 180,000km
Built and tuned by C V performance and Unique Autosports.
Interior and Exterior is in Excellent Condition
Timing Belt and Drive Belts all Changed again at 160,000kms
Serviced Every 5000Kms
I will sell this car with 12months rego
THIS CAR IS IN A1 CONDITION AND INSIDE AND OUT!
$14,000
Ian, please call after 7pm: 0413198060
Modifications
Engine: Apexi Power FC with Boost Control
GCG Hiflow turbo with Nissan VG30 turbine housing (480hp)
Nismo 550 cc Injectors
Gates racing timing belt
Nissan GTR34 Intercooler
Nissan GTR34 Fuel Pump
Bosh 044 Fuel Pump feeding Serg Tank(3L)
Sard Fuel pressure regulator
Nissan Z32 Air Flow Meter
HKS step 1 256 and 264 cams with adjustable HKS cam gear on exhaust side (VCT remains)
K&N filter in stock air box
Earls Oil Cooler
6 Boost exhaust manifold
Kakimoto 3" Exhaust
4" Magic Cat
PWR alloy radiator
Extreme Heavy Duty Clutch
Power: 250rwkw 16psi
Suspension: Whiteline Adj Front and Rear Sway Bars
Adj Castor Rods
Bilstein Shocks
Whiteline Springs
Whiteling Adj Camber Kit
Whiteline Adj caster bushes
GTR Geoff Hicas Lock Bar
Cusco Front and Rear Strut Bars
17" DTM rims
Nexen 235/45z/17 (70% tread) tyres
Brakes: Ferodo DS2500 Pads Front, Stock Rear
DBA 4000 Sport Sloted Rotors Front, Stock Rear
Cusco Brake Master Cylinder Support
Speed Flow stainless Braided brake, clutch and oil cooler lines
Oil Temp Gage
Boost Gage
Apexi Power FC Hand Controller
Alpine Head Unit
6.5" Fusion front speakers
6.5" pioneer Rear Speakers
Tinted windows
https://www.sau.com.au/forums/topic/262353-fs-r33-nsw-14000-ono/
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
