I'll be very interested to know the answer to this as well.
My gut feeling is that a HD kit for the R32 RB20DET would be the right option ( PUSH type / 240mm Dia ) but I would really love to know for sure !
https://www.sau.com.au/forums/topic/262453-r34-25gt-clutch/#findComment-4508518
Actually, after searching a bit I found the following
SPORTS TUFF Clutch Kits (Australian made for improved performance)
Heavy Duty Kit: NSK-7333HD
SKYLINE- GT-T
Year Application
98-on
R34, 2.5 Ltr, RB25DET (Pull type)
I now have less confidence in the response from Exedy being correct :sick:
https://www.sau.com.au/forums/topic/262453-r34-25gt-clutch/#findComment-4511348
Spoke to the guy at Exedy again and he's positive that the NSK-7333HD kit is the one to use.
What someone ( I'll try to but it won't be for a while ) needs to do is to unbolt the slave cylinder and pop the clutch fork dust boot off and see if this is a push or pull set-up. If it IS a pull type clutch, the above kit should be good.
If it's a push type clutch, I would be looking towards a HD early R32 GT-R organic kit.
https://www.sau.com.au/forums/topic/262453-r34-25gt-clutch/#findComment-4515439
See, here's the thing. AFAIK, R34 GTT ( RB25DET ) has a PULL type clutch. I'm almost certain that the R34 GT ( &GTV ) use the PUSH setup which would make them equal to R32 GT-R RB26DETT ( early ) and R33 GTSt RB25DET ( both are 250mm dia from memory ). If THAT is correct, it would be great ! That would also mean the rep for is Exedy wrong.
Can't wait to put this one to bed !! It's been bugging me since I first looked under my car years ago :(
https://www.sau.com.au/forums/topic/262453-r34-25gt-clutch/#findComment-4515874
  • 1 month later...
NSK-7056HD
Details:
• Diameter: 240mm
• Spline OD: 25.50mm
• No of Teeth: 24
• Pressure Plate Type: Push
• Pressure Plate Clamp Rating: 8428N/860kgf
Applications of this item are as follows:
• Nissan Cefiro A31 (RB20DET)
• Nissan Laurel C33 (RB20DET)
• Nissan Skyline R31 RB20DET (Import)
• Nissan Skyline R32 GTS-t (RB20DET)
• Nissan Skyline R32 GTS-4 (RB20DET)
• Nissan Skyline R33 GTS25-t (RB25DET)
• Nissan Skyline R34 GT (RB20DE)
• Nissan Skyline R34 25GT (RB25DE)
:D
https://www.sau.com.au/forums/topic/262453-r34-25gt-clutch/#findComment-4572368
I got a new organic clutch and a heavy duty pressure plate installed here in melbourne for a gtt with 230 rwkw.
The pedal is heavier than stock but its a nice clutch. reused the original flywheel after machining it.
Hope this helps, i originally got an exeedy clutch and hated it. mind you it was a carbon one,
DONT GET A CARBON CLUTCH PEOPLE! :P
Turned into an expensive exercise.
Goodluck
https://www.sau.com.au/forums/topic/262453-r34-25gt-clutch/#findComment-4573224
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
