wassup all , i need some stock bars (4 door , front is same as 2d but rear different) i may swap the kit but i really want gtr front bar with stock sideskirts and rear pods (or vertex/dmax side and rear)
also i want a set of aftermarket shocks/springs ,
manual gearshift boot and surround
manual tailshaft
caster rods
boost gauge (preff 60mm)
and a front pipe (screamer would be nice)
theres probably more , i'll add if i can think of it . cheers
R/h headlight
r/h plastic wind visor thingy (it goes over both doors at the top)
l/h mirror (i have a pair of ganador type , but i don't like 'em , i might swap for a good pair of stockies)
east bear tail light covers???? , theres more but i forget
https://www.sau.com.au/forums/topic/262455-wtb-r32-parts/
manual tailshaft
caster rods
i have a left hand mirror off my R32 GTR throw an offer if you're interested
R/h headlight
https://www.sau.com.au/forums/topic/262455-wtb-r32-parts/#findComment-4502557
manual tailshaft
caster rods
R/h headlight
Hi toffy
I have a pair of front tein coilovers that are off my gtr and will fit gtstno leaks or damaqge.350.00
I also have a pair of stock mirrors red. if i like your granado type i may swop.
I also have stock side skirts red no damage 300
stuart
https://www.sau.com.au/forums/topic/262455-wtb-r32-parts/#findComment-4502600
whoops. i have a left hand mirror off my gtr if you're interested
haha i was wondering what your first post was about :P , sorry i'm picking up a l/h mirror in the morning, thanks anyway
Hi toffy
stuart
i'll let you know mate (i don't need the mirror , but i may want the coilo's and skirts pending whether another guy on these forums wants to post the ones i enquired about :P ) , i gotta come up n pick those trim bits (and maybe the bonnet) from you soon , i'll pm you as soon as i know whats going on with the other stuff i was asking about in your thread :D
these the type you have toffy?
http://www.gktech.com.au/products/?ID=112
nah theyre not like the gktech ones , although i do know someone with a set they wanna sell , the ones i have are electric and have led indicators on the front face :)
i can't update the first post so i'll update here: i'm purchasing l/h mirror rear bar and l/h 4d side skirt (only the left , would still need the right) , pending postage i also will have headlight and coilovers . cheerio
https://www.sau.com.au/forums/topic/262455-wtb-r32-parts/#findComment-4503013
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
