Wanting to sell off my R32 GTS-T are my BIM Zeit Version SS in Bronze.
They are a 17x8.5JJ with offset 32.
Tyres are Neuton NT 5000 235/45ZR17 still in legal condition.
The rims are still in great condition although 2 of the 4 have a bit of gutter rash. I only have 3 of the 4 centre caps as they came with the car when i bought them and thats all the fella had.(I personally prefer them without the centre cap anyways).
Was chasing $750 or possibly swap for a set of R32 GTR wheels with some cash my way.
I can come as far as Brisbane/Gold Coast as I'm bit north of the Sunshine Coast.
Cheers
https://www.sau.com.au/forums/topic/262535-bim-zeit-version-ss-bronze/
