hey guys,
well tonight i went and grabbed some nandos - delicious, however when i returned to my car and went to put it into reverse the clutch felt way odd, there was no pressure until it was basically in..
now from memory i hav an exceedy heavy duty organic clutch and it is(was) mad..
soooo is my clutch about to shit itself or could the pressure plate need tightening??
as you can tell im quite the n00b when it comes to knowledge of clutches..
and ideas/advice would be great
thanks in advance :banana:
https://www.sau.com.au/forums/topic/262693-clutch/
your pedal wont lose its pressure due to a worn clutch plate
check clutch fluid level (its actually brake fluid in there)
then go from there
cheers mate - checked that out, refilled and now we're all sweet :bunny:
...touch wood :banana:
https://www.sau.com.au/forums/topic/262693-clutch/#findComment-4499073
I think if you wasnt a full bogan from logan :( it wouldnt of happened in the first place!
man i'm not from logan! and defs not a bogan.. (haha shyboi:P)
...at least my car drives without space savers :D
just to add you may want to look into why the fluid was low as a clutch or brake system should be sealed and not 'use' fluid the only time it will run out is if there is a leak.. hope it helps.
cheers bud - im going to investigate the leak this weekend :woot:
https://www.sau.com.au/forums/topic/262693-clutch/#findComment-4500331
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
