Hi guys,
I'm not really sure of which section to put this in so if this is the wrong spot then please move it.
The issue i'm having is that the needle on my boost gauge seems to of somehow wound itself all the way around and it is now stuck behind the little black stopper you can see in the pic. When I turn the car on I can see the needle trying to move but its stuck behind the black thing so it cant go anywhere.
I have taken the boost gauge out to see if I could somehow wind it back around myself but I cant see a way to do it, ive checked all the wiring / lines and they are all in there right spot.
Does anyone have any idea what would of caused this? the digital boost readout on my turbo timer reads out as normal just the GReddy gauge is stuck for some reason.
Attached pic is of my actual boost gauge when its sitting in the normal spot I don't have a pic now that its stuffed but now it just sits on the right side of the black stopper stuck there.
I should also mention that I just changed from a high flow turbo back to a standard one when this problem came up but not sure if thats related in any way.
thanks
https://www.sau.com.au/forums/topic/262728-weird-boost-gauge-issue/
hahaha that's weird
when the car is off, the needle should sit at 0. so i cant imagine how it got behind the stopper.
and if these are like most other gauges, theyre not meant to be opened, so there wont be easy access to get to the needle.
i doubt its anything you did that caused this. maybe the needle isnt sitting in its base properly, its loose?, and thats how it got down there. who knows. you'd have to try and open it i guess.
Well my laptop did flash up DANGER TO MANIFOLD and then my floor pan fell out then I noticed the boost gauge was going crazy.
Ok Fast and Furious jokes aside, I attempted to open it up again lastnight but theres no way you can open it to touch the needle, and the needle and stopper are both tight, so to get there it definately somehow wound itself all the way around.
Im sure ill get to the bottom of this mystery oneday!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
