Some prices are neg. Craig. MOB: 0439691454 email: [email protected]
here are 6x nismo 555cc side feed injectors for rb25det, sr20det, 13bt etc. with all O-rings, washers plugs and rubbers and grommets. they have been cleaned and flow tested as well, this alone is over $120. they pushed out 660cc/min on the flow bench so nothing to worry about. with recipt to prove. $700 pick up. or interstate postage (buyer to pay).
here is a used Z32 AFM with plug. $150
here we have a walbro 341-gss 255lph (with all the mounting gear plugs etc). it has the same internals and ratings as the 342-gss. the only difference being the outlet. the 341 has the outlet on the other side of the inlet. where as the 342 has it straight in line with the inlet. it will not make a difference whatsoever. $110 pick up. or interstate postage (buyer to pay).
here we have a r33 gtst used sard top intake sports induction kit with bolts to mount it. $40 pick up. or interstate postage (buyer to pay).
here are 4x r33 rims with brand new nexen 16/225/50 rubber. $500 the lot. the rims themselves have oxidized streaks in the clear coat. probably from brake fluid from previous owner. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here are 4 mazda eunos rims, no tyres, with the 114 pcd 5stud pattern. $100 they fit the rear but will need spacers to fit the front. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here are 3x 17 235s rubber only 1 is federal 595ss the others are falken 326's. 35-40% the tread is above the wear indicators.
pick up. but can deliver in sydney for $25.
here are stock r33 gtst front and rear sway bars with rubbers. $40 ea. pick up. or interstate postage (buyer to pay). can deliver in sydney for $25.
here is a series 1 front bar for an r33 gtst. needs a respray $60 pick up. can deliver in sydney for $25.
here is a LHS fender it needs to be resprayed and pannel beated slightly for the dint and the headlight surround. it would do for a drift car though. the damage is minor. see pics. pick up only.
here is a left over sheet of aluminum mesh.$15. the largest part measures 59cm L x 27.5cm W. the but overall it is 121cm L. pick up only.
here we have 2x universal racing harness's (one red and the other black). with all of the hardware to fit them. i will separate these. $50ea. pick up or buyer pays postage.
here we have 2x r33 gtst whiteline subframe split pineapples. these are split so they can be fitted to the upper part of the subframe bush. used to set the car at neutral stance when used with 2 other pineapples. $10 pick up. or interstate postage (buyer to pay).
here we have a 2.5" x 3" silicone/rubber intercooler pipe join. $15 for the join. pick up. or interstate postage (buyer to pay).
here is 1 LHS 400r nismo side skirt in primer still needs prep work. $40 pick up. or can deliver in sydney for $25.
here is an r33 gtst stock radiator perfect condition. needs to be cleaned and flushed by a pro shop. $40 pick up. or interstate postage (buyer to pay).
here is a holden commodore VT washer bottle pump and a one way valve to stop the hose leaking when the pumps not in use. for a DIY intercooler spray kit. $30 delivered.
here is a suzuki swift ,and gti, tie rod end brand new $10.
Edited by Trust33
he's from sydney (or so i think from the part he sed he'd deliver in syd yadda yadda)...
where bouts in syd are u? got any pics of how the sard intake thingo sits in engine bay??
hey. i think i do but they are amongst some old photos. i will have to get them tomorrow.
hey mate you had a quick scan for what? i am located in ingleburn.
he was after where u located lol
yea shoot up a pic of two i'll probs take it if it acts like a pod enclosure blah blah thing
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
