Just seen a trailer for the new fast and the furious movie. there is a drag with vinny in his dodge charger, wheel standin off the line and next to him is paul walker in a mad blue skyline, cant tell if its r33 or r34 but its mad. cant wait for the movie, ill try find a url to the trailer and/or movie.
cheers
https://www.sau.com.au/forums/topic/263201-fast-and-the-furious-tralier/
Well fellas, not long to go, 2 more weeks and the movie is official released in Australia...whereas Paul Walker and cast and crew of the movie is doing the red carpet opener April 4 or 7... Google it to make sure.
The trailer shows Vinny in a Dodge Charger versus a R34 GTR in blue...looks stock with Nismo Kit... the movie will be more of an cop action movie than a car movie as we've wanted so will be kinda disappointing, I think...
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
