I am selling Selling Skyline GTS25T R33 1994, and I am looking at about $5,500. I had an accident, and as you can see on the photos, i am selling the vehicle as it is. Any offer is welcomed.
This car was directly imported from Japan. This car had an accident, and front right hand side been damaged, but the bonnet is fine.
Car Detail:
4x 18 inch chrome wheels + 2 extra wheels
Refurbished RB25DET engine
excedy sports clutch (6 months old)
hybrid intercooler
full performance exhaust system and 3inch cannon
boost controller
Performance air filter (Pump back system)
Sunroof
Spitfire tacho
Tinted windows
Full body kit
Boss steering wheel and stepping wheel kit
clear head lights (Left hand side only) and indicators fusion
pioneer sound system and amplifier
175,000km
Rego expires in end of July
Dyno was in Marrickville, it has stocked turbo for last 10months but had a garret turbo replaced, injectors, normal fuel pump and computer.
Please either send me an email or call me on 0424 188 790.
https://www.sau.com.au/forums/topic/263301-selling-skyline-gts25t-r33-1994/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
