Adding A Carputer To My '03 350gt Prem... Want To Solve The Nav/movie/music/internet Problem Once And For All!
  • 1 year later...
  • Replies 83
Posted Images
I saw talk of an Overlay for the standard screen. Is this still an option? is it USB? if so, does it have a driver for windows to act like a mouse?
I have searched for USB overlays, they are really cheap ($55) but they are not quite the right size. Still looking.
Obviously I am planning on a Carputer. For Navigation, I previously use TomTom on my windows phone. I also have found freeware that basically lets me control and view the phone's screen on a computer, via the USB into my phone; sorta like remote desktop / VNC. Also, by plugging in my phone over USB, I can also use my phone as a wireless internet interface, so my Carputer will have internet also (ie google maps with traffic)
I have also found that JayCar sell the 12v power box for a std pc. So I plan to try an old 1Ghz P4 I have lying around.
My problems I have at this time are:
1. How I will handle the shutdown / power-down of the PC. Also the strange power conditions during engine startup.
2. A single USB2 cable is 5m max, USB1 is 3m (my old PC is USB1) It will need to reach the screen for the Overlay, and I also want another one to pop out just behind the screen to plug in my phone.
3. Will start with the Std old HDD in the PC, but look for an SDD, do not expect the HDD to last too long, especially with my low profile tyres.
4. The Overlay, its install, the usb cable length. Will use a trackball system if I can't sort this out at first.
5. The VGA to NTSC conversion. Resolution? running XP at 640x480 with the current screen as output.
6. Hope to use the ODBII cable into the PC later, but a little concerned as to cable length as PC will be in Boot. Also sceptical regarding the display on the tiny low-res OEM screen.
Thats where I am at now. Also sent an email to Chris (cant do PM's yet) regarding the AUX cable / adapter into the TV in the boot; which is where I plan to put the PC.
Any comments or further problems I may encounter please feel free to put up.
Edited by vee35
Iive installed a carpc on mine too. G33K is right, the only properly working obdii scan tool is BlaZt. All gauges work only with NDS (Nissan Data Scan) 1.3. It comes a as a bundle when you buy the adapter.
I'm beta testing the 1.4 now and man, it's got soo much potential. Can even unlock control your interior lighting even turn off the beeps. All from the software. The only downside for me, is that it can't read codes off my tcu/tcm since i got a gt8.
I'm in Perth and willing to help anyone to install a car pc on their Vs if they're keen ;)
Thanks.
My one is working flawlessly, however, i've upgraded to the TPMS that i posted a while back so i don't use it for scans as much anymore.
Other than that - the CarPC is a charm! <3
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 馃
    • Have a chat with the tuner, you'd want to drive the car straight there.
