  • Replies 494
Posted Images
sounds good i ll see wat happens.
i want this whole topic thing to be used for and by gold coasters like if u spot someone or u wanna plan something. or just wanna tell a story so yeh people feel free to write whateverr.
well my old man is a retired mech so what i cant do i hit him up for. Brendan said eairlier that he is a 3rd year mech workin at a shop he has with his old man.
Gavin wood in labrador are also well spoken about.
For tuning id go to spry
yeah we have a workshop down in southport, 2/78 davenport street called M&S Auto Repairs. we do a fair bit or work on imports and any other sorta cars. servicing, tune ups, clutches, brakes, engine work, auto to manual conversions and any ohter sorta mechanical needs. we are willing to help out members to this site so feel free to call us on 5531001 for quotes. we also do roadworthy certificates.
cheers
Brendan
CRUISE IS SET TO 7TH OF JUNE (due to coz i didnt realise there was another thing happenign on the same day)
More infomation is in the Events section under EOI for a cruise
see ya there!
Brendan
Edited by 13rendan_88
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
