fkn oath! - if anyone is wondering, i played this guy in CS like a year ago and for some reason we added eachother and hay presto a year later we find out we both have R34's and we spend most of our job time on SAU :P small fkn world!
hahah f**knin small world aye
old CS hahahha
I used to be a full PC nerd then i got married and became a car freak .. . . . . lol
  • Replies 494
Posted Images
Hey Dan I think we heading up the hills again on sat or sun arvo (24th, 25th) if your keen just send me a txt a bit closer to the date and ill let ya know whats going on :rofl:
cool man wood b mint what times was you thinkin?? :D
Hey Dan!
There's a drift event at broahbeach today from 3pm to 10pm.
http://www.racelineevents.com/raceline/
Hey bud I was in Melbourne so I couldnt go :) Did you check it out ?
f**k it cant get out of work man! :D my cars not moved for weeks now.
Hey man ended up hitting the piss on sat night and was way to smashed to drive on sunday so unfortunately I didnt get to take mine for a spin last week either :D
Ill give ya a buzz when I sort out the next one :)
Yea. It wasnt too bad but not really a lot of "show" cars around. The drifting is alright. I went later at night but left after an hour or so.
How was melbourne? Did you leave a trail behind? Hahaha
Ah k
Melbourne was awesome bro, real good to spend some qt wit the fam :)
Theres about 60km of that great ocean road that ide love do do in the line :banana:
well its more a matter of time, still lots to do and i seem to keep changing my mind on fabricating parts for it. im hoping within the next month.
but then need to get it run in and dyno tuned
Ah k sounds like your doing the full over haul . . .
What you got going in if you dont mind me askin?
Just the old 20. but with a few tweaks. around 350rwkw or more
A few tweaks ? ? ? :/
350rwkw is prob a little more than a few tweaks lol
Ah well sounds good man that thing will fly, your only prob will be gettin it to hook up ;)
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
