You ask an interesting question there.
You can either have it curve up over the radiator and square off over the cam covers or cross over underneath and have two pipes go back over.
The "over" way makes general head maintenance even worse but it makes upg. to a front plenum easy.
The "under" way makes a front plenum hard.
T.
My intake piping near the throttle body/engine/radiator was a shitload hotter in the factory location, when compared to the new piping in the front-facing location which doesn't really go near any of those aforementioned things.
I've been told by a few people that the air moves too quickly for heat soak to be an issue, but i dunno, the old piping method is so long that it has to have at least some measurable effect.
Edit: my old intercooler was still front mount, so the piping near the radiator (under) wasn't "factory" as such, but the rest of it was fairly stock standard.
The less clutter their is in an engine bay the better I say. I've got the piping going underneath and although the piping is alittle longer it leaves much more room for other things like oil coolers etc etc.
Not only thing but almost every engine bay i've seen with the 'behind the radiator' has had issues with bonnets or repairs or removing/replacing parts etc.
I dont think it would make a huge difference from a performance point of view, apart from pipework being a bit longer if you go with the stock location, but I had a couple of other considerations that I used in the choice, they were:
I was planning on swapping to a front facing plenum
I wanted the hole that is freed up in the front of the engine bay to be used for a CAI
For the size of cooler I wanted, it was difficult to find one with an end tank design suited to using the stock pipe locations.
Hi T0nyGTSt, there is 3rd way, by having a 120 degree bend at the throttle body. Saves about 800 mm of pipework and no need for it to run behind the radiator.
I'll dig up and post some pictures of the Gibson R31 and an R33 that had the same system.
I have had a fair bit to do with an RB25DET with the 120 degree setup. Made 251rwkw with stock injectors and internals. Happens to be a green Silvia in the latest issue of Zoom (No. 69...)
Seemed to work fairly well. The 120 degree bend did get condensation on cold nights with high boost so I assume there is a noticable pressure drop around this area.
IMHO...
Originally posted by T0nyGTSt
In the interests of further education, I present this pic:
http://www.nitroware.net/~tony/r32_120d.jpg
I must admit is it not too common as I've never seen one in the flesh so to speak.
T.
Probably because it's so fugly :D
Well do you want the benefits of shorter pipe work?
or
Do you want neat and tidy wank appeal ?
why does no one consider running the pipes in opposite directions if you want to keep the 'in between raditor/engine' tidy apporach? as in come out of turbo, behind raditor, thru intercooler, up thru stock postition, then into cross over pipe....
I already have them, and shorter than that. Sorry if your car is done like that and I offended you, I didn't mean to. It's just my opinion, and probably a lot of others or I'm sure we'd see more of it around. Ok it's not fugly, just seems a bit "untidy" to me. But each to my own, I'm not going to bag it out! I was kidding earlier. There are much fuglier engine bays than that one :D
yeah why dont more people run the piping the way Skyrine-Dave said?that way you at least have the intercoolled air exposed to the heat of the engine bay for the least amount of time,except if you have a front facing plenum.my sons r33 gtst is done this way & doesn't seem to have any probs.
cheers
warrick
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
