Hey guys,
Have an R33 GTST making just over 260rwkw that I will be doing some track circuit/drift days in. I also drive it on the street probably twice a week.
I believe my brakes are completely standard and want to upgrade but dont know exactly what to use exactly in terms of brands & parts also dont want to spend bucket loads.
I want the brakes to obviously remain strong once they have heated up & want a setup that will help the handbrake to always lock up on entrances. Ive noticed after few pull ups, the handbrake starts to get a little lazy and the wheels dont really lock up.
From what i have been told so far, i should do the following. Please confirm im not going wrong anywhere.
Front Braking
-Retain standard fron calipers, but upgrade Pads
-Get new bigger cross drilled discs
-Upgrade brake fluid
Rear Braking
-Get URAS rear brake kit including shoes & pads
Your help and advice is much appreciated
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/263714-upgrading-brakes-front-rear/
Check here for Brake Pads guide, everyone gives their opinions on a large range of pads:
http://www.skylinesaustralia.com/forums/Br...gs-t169972.html
You might also want to look into some Braided Break Lines, there is some for sale in the GROUP BUY section. And maybe a brake master cylinder stopper to give the pedal a firmer feel.
Along with some better fluid, this will help you car pull up time and time again. Cheers.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
