i dont know any part numbers but i have needed to replace my M35 needs front sway bar bushes and rack ends at 45000kms are they the same bushes that have worn out on your car. somone could ad these part numbers to the list as well thanks. im currently chasing these numbers. I just had my car serviced at North East motor Repirs and it was very interesting underneath.
i rekon any suspension place can supply swaybar bushes, just need the diametre of the bar. as for rack ends, ni$$an might be the only option
On my car the bushes that are gone are the lower compression rod bushes. Nissan want 340 each as its the arm assy. I got one from yahoo so I have the broken one spare and would like to try source a replacement part for this.
radius arm ones are common to fail and there should be after market parts in your area as they are also on 350 Z yes?
Radius arm? which ones are these? Ar they the ones most furtherest back near the driver and passenger foot wells?
I got an arm second hand ex japan $30 said it was for an NM35 when I had a look at it against mine it was different and wouldnt fit due to the front drive shafts. The bush was the same though.
did a bit of research and the c-rod I got was off a G35 or V35 which is a little different and wont fit. See picture (Black part), Im only looking to replace the bush at the end.
yes those are the ones I just replaced for the second time, most common to wear but mine were improperly installed
available as separate part here in NZ ($70 NZ each)
that's the tie rod I just replaced below it ($200 NZ)
scoured the net and it looks like we can use these bush kits.
http://www.nengun.com/nismo/suspension-lin...-parts-350z-v35
http://www.mynismo.com/products/Default.asp?id=5348
thinking about ordering a complte kit and replacing all bush's
but read the small print:
"Designed for competition, more vibration will be transferred to the cabin"
and it looks like they're mostly supplying rear suspension bushes
many of the front bushes can only be obtained with arms/links attached but the ones I bought weren't that expensive at that time
they were:
54618AQ300 - rod assy stab m35 (one)
54668AQ300 - rod assy stab m35 (one)
54618AQ305 - rod connecting stab m35 (two)
all were $50
of course more vibration will be transferred to the cabin, they are a firmer bush, soft ones absorb the vibrations, but they wear out faster. so you need to have a cup of concrete and harden up and get the poly bushes :wacko:
$50 isnt too bad, but its still a rubber bush
  • 1 month later...
I am having the same issue with the same bushes as well,
I am waiting for a quote from a JDM importer at the moment,
more liky i will be buying a new control arm as I think should be a good idea to replce the whole thing cuase i want to get a new ball join too.
I agree, the more I look into it Im going to order the genuine arms as I dont really want any problems with it. At least then I know that they wont wear out in the lifetime I have with the car. The problem is that when I costed them last they were $340 each, hope they havent gone up :)
Just got a call from the guy who i used for a long time...
he told me he can do it for $ 290 and send by ems shipping.
but then he told me if i can afforded to order another one ( LHS and RHD ) he can possibly make it a bit cheaper as in the cost would be less...
Due to the unstable econ climate, I just order one for now...
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
