hey guys
yeah before people say *search* :) i have but gotten quite a few different responses and there was a bit of confusion about them, but that was a while ago
so just wanted to know what are the brake pads for a r33 gts25 s2 n/a obviously
Is it DB1144 and DB1308 which ive seen on the forums.
or is it
DB1165 & DB1144 which i saw on the bendix website
im thinking of buying some from supercheap or autobarn or something and getting a mechanic to do it as im doing a level 2 driving course at murcotts on wednesday & dont have the time to try and do it myself :wacko:
https://www.sau.com.au/forums/topic/264335-r33-na-brake-pads/
ahh buddy.. in regards to the front brake pads . I'd try getting these ones in case . because i had lots of trouble before regarding it . there maxistop m-d-b 8382 or find other pads that compare to it
I went to the bendix site and sent them a query email and gave me the part numbers for my NA R34 Sedan (Not GT-V).
These are the part number for the NA R34 - not sure if they are the same...
Front:DB1308
Rear:DB1144
Just out of curiousity, does anyone know how much they retail for at Repco etc? Also what options are available, regular, sports pads...?
According to Bendix website they have a standard pad and a heavy duty pad to suit work utes but no sports option.
Originally i was looking for Bendix ultimates but decided to go for General CTs instead due to the other advantages and the fact I realised i don't really drive my car that hard majority of the time.
I did give them a good run on my last trip to great ocean road and thought of them highly.
The Bendix General CT (ceramic), retail for around $70 for the front and about $90 for the rear... odd considering the rears are smaller :P
Things to note about the General CT - as it may not suit everyone's needs.
- Slightly softer feel - less feedback - but you can definately feel them grabbing.
- Good overall performance - not as good as the heavy duty (metals) for long high speed braking - but still very consistent and competent for the price and other advantages. If your really need to slow down from high speed best down shift. ;)
- Quiet
- Minimal dust
- Great grabbing power when brakes are stomped.
- Smell nicer - smell like buscuits - if that even matters hahaha :D
- Most likely wear faster (I also have genaral CT on my Bluebird and have noticed this) - but at least your rotors will last longer....
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
