Hey Guys,
At the moment when I turn the car there is no noise at first but as soon as it warms up a tiny bit this grinding noise appears when the car warms up fully the noise seems to quieten down and even subside. The car is usually stationary when this happens.
The grinding type noise is coming from underneath the car around the clutch/clutch fork area. You can audibly hear it.
I was just wondering whether this could be a fly wheel issue. The noise is definetly coming from underneath (around the middle of the car) not the engine or the wheels.
Just hoping some of you have had this kind of thing appear. I have taken it to the mechanic but the car did not make the noise then. Which was really annoying.
Edited by LatinR33
does it change when you apply the clutch?? does it change if its in 1st or neutral?? most likely a bearing in that area.. throwout being the most obvious, input shaft being next.
I havent noticed any change when the clutch is in.
"most likely a bearing in that area.. throwout being the most obvious, input shaft being next."
If it is this how much would this bring me back money wise??
When I put the clutch to friction and reverse the car out of the garage it sometimes becomes louder. The noise is tempermental though which is annoying. Also in neutral it goes louder and silent then louder and silent. Once warm usually dissapears.
Edited by LatinR33
sounds like a throwout bearing... $20 for the bearing, but the gearbox has to come out.. so if your not handy with tools and have an area to work in.. you'll need a mechanic with a hoist to get it out.. changing the bearing takes 2 min with the box out.
Whats the best way to determine if it is infact a throwout bearing??
Does the box have to come out completely?? Thats going to cost a fortune isnt it for such a inexpensive part.
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
    • Yep, cheapest options, neglected and abused. The fastest way to dislike a car is to get assigned that model by a budget rental company
    • The noise complaint could be from absolutely anywhere, and anyone. Get it actually noise level tested to find out if you're actually over, or if you're fine. If you're over, quieten it down. If you're under, carry the test results in the car with you.
    • SAU NSW x Benzin Cafe Cars & Coffee Sunday 12th October 2025 7:30AM Meeting Benzin Cafe Meet Location: Benzin Cafe Dural RSVP: https://forms.gle/Q9TcFu9DHe4dbvtKA   *Disclaimer* One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
