FOR SALE 1994 R32 GTR skyline
Gunmetal Grey Duco
Croydon racing developments and perry engineering played a part supplying and building the engine!
aprrox 15000K's since rebuild
R33 Block (chemically cleaned, rebored and honed, surface ground and crack tested, tunnel bored 7 main tunnels)
R33 Crank (crack tested, machined and balanced)
Race series conrod and main bearings
Forged Pistons
Rebuilt Head (machined, pressure tested)
Tomei oil restrictor
ARP head stud kit
ARP rod bolts
Custom 7.5ltr sump with tomei baffle
Complete tomei gasket kit (including metal headgasket)
*engine has alot more bit like new welsh plugs ect all listed on receipts*
Gates timing belt
Tomei Cams
OS giken cam gears
N1 oil pump
SARD 700cc inj
K&N element filter
Stainless engine pipe
Stainless dumps/front
Full 3inch system (very quiet but gives a nice note)
R34 BB turbos
Remapped ECU
NEW fuel pump (was told its a GTR pump but sounds a bit loud to be a stocker)
engine bay has been cleaned up was polished bits n bright red bits but removed nearly all pipe works covers and have now been painted in satin black engine enamel i even replaced the pod filters with a stock airbox and new element filter, just looks alot neater imo
Currently making 280rwkw @ 15psi (this engine was making 370awkw with hks turbo set up unsure what turbos it was running)
dyno sheets for both
New extreme clutch and machined flywheel (with new master and slave cylinder)
5 speed gearbox (receipt for being stripped down and checked, replaced shift keys pivot ball and 4th gear syncro)
Tein coilovers
Whiteline Swaybar nolathane link bushs
all New nolathane bushs for rear arms (not yet installed will come with car)
R33 GTR Wheels
New slotted DBA rotors
New pads
Tint
Alarm/immobilser
Aftermarket steering wheel
Switchs for ABS, RWD and thermos
Torque split controller
Digital speedo/0-400 timer
TKO 300+ speedo
this car comes with many modifications and many replaced parts, Receipts for nearly all the work that has been done including the basics in past years like cv boots/steering rack boots ect all i wanted to do to finish her off was Z32 AFM's a bigger fuel pump and i would recommend -5's and she will be a weapon!
this took me more then 6 months to find and for ppl who know me and know how much of a impulse buyer i am they will realise i waiting for something amazing this time! selling due to finances, i work at holdens and will be going back to day shift but it maybe 1 week on 1 week off which will cut my pay rather badly but i want to clear my debts and hopefully buy a block of land in a new development area near me so clear this loan i should be able to scrape through for the land :s i dont really want to sell but sometimes you gotta make sacrifices :nyaanyaa:
Car is located in Adelaide (northern suburbs)
asking $22,500
PM me if interested!
Edited by shy_s6
https://www.sau.com.au/forums/topic/264393-for-sale-94-r32-gtr-gunmetal-grey/
  • Replies 60
Hi,
I'm trying to get in contact but can't because I just signed up here and need to get 10 posts :)
will make an offer as soon as i can get in contact, im in perth, finances all in order just looking for the right 32gtr.
Hi,
no drama's bud she is still for sale many offers but nothing that will help me out finacially
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
