butch Posted April 6, 2009 Share Posted April 6, 2009 gday fellars . had this on the hoist the other day and only one wheel was spinning ... is this normal i would of thought it came with a limi at least or can anyone correct me on this . cheers *R33 Gts n/a 93 model lsd or single spinner ??? Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/ Share on other sites More sharing options...
natho33 Posted April 6, 2009 Share Posted April 6, 2009 they are a single spinner mate Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4521732 Share on other sites More sharing options...
alex1991s Posted April 7, 2009 Share Posted April 7, 2009 Depends on what model, if yours is a 33 type-s then yes it does, if your model isn't then it was optional. http://www.cars-directory.net/specs/nissan...e/1993_8/21713/ Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4522045 Share on other sites More sharing options...
WGNC-34 Posted April 7, 2009 Share Posted April 7, 2009 hey, from what i could gather when i had my skyline which was a 93 model n/a it was viscous lsd,they get pretty tuckered when they get older,and the result is pretty much a single spinner. Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4522419 Share on other sites More sharing options...
-Jimmy- Posted April 7, 2009 Share Posted April 7, 2009 R200 diff from the turbo model should bolt straight in I think? I think there are things to consider like ABS braking but a shimmed up one of them will be plenty enough to get both wheels spinning. Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4522590 Share on other sites More sharing options...
Line 3 Posted April 7, 2009 Share Posted April 7, 2009 i got a ecr33 and it spins both Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4522723 Share on other sites More sharing options...
LUME Posted April 7, 2009 Share Posted April 7, 2009 (edited) mine never did with the standard suspension (93 model) but now all i have to do is dump it in first at about 5500 and gets both going with the coilovers very nice its a totally different car it was the best mod i ever done Edited April 7, 2009 by LUME Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4523329 Share on other sites More sharing options...
-Jimmy- Posted April 7, 2009 Share Posted April 7, 2009 Coilovers is also the best mod I ever did to my NA Skyline, but people may argue that good adjustable sway bars are probably the best Bang for buck suspension mod. Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4523393 Share on other sites More sharing options...
Line 3 Posted April 7, 2009 Share Posted April 7, 2009 well mine has ajustable suspention she handles like its on tracks and mine spins first and spins second was it a certin model that had a lsd?? Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4523421 Share on other sites More sharing options...
butch Posted April 8, 2009 Author Share Posted April 8, 2009 Depends on what model, if yours is a 33 type-s then yes it does, if your model isn't then it was optional.http://www.cars-directory.net/specs/nissan...e/1993_8/21713/ er33 is the model i have . and whats this talk about an r200 diff ?? Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524646 Share on other sites More sharing options...
butch Posted April 8, 2009 Author Share Posted April 8, 2009 also is the camber adjustable on the rear . the tyres seem to wear on the inside pretty quick Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524655 Share on other sites More sharing options...
G0DZLR Posted April 8, 2009 Share Posted April 8, 2009 mine never did with the standard suspension (93 model) but now all i have to do is dump it in first at about 5500 and gets both going with the coilovers very nice its a totally different car it was the best mod i ever done and then you crashed Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524680 Share on other sites More sharing options...
LUME Posted April 8, 2009 Share Posted April 8, 2009 (edited) no... found the problem turning left + loose roads and immense toe in on the rear mechanic said that was the culprit i wasnt trying to slide like ive stated in the other thread. Edited April 8, 2009 by LUME Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524786 Share on other sites More sharing options...
G0DZLR Posted April 8, 2009 Share Posted April 8, 2009 wanna see some pics of it on its coilovers Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524787 Share on other sites More sharing options...
LUME Posted April 8, 2009 Share Posted April 8, 2009 mine? Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524819 Share on other sites More sharing options...
G0DZLR Posted April 8, 2009 Share Posted April 8, 2009 Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524821 Share on other sites More sharing options...
LUME Posted April 8, 2009 Share Posted April 8, 2009 (edited) it doesnt sit lower in the front i have measured it and theyre both dead on Edited April 8, 2009 by LUME Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524900 Share on other sites More sharing options...
R33 Ribby Posted April 8, 2009 Share Posted April 8, 2009 nice car but it needs a kit lol. what coilovers are you guys running like type and spring rates? oh and keeping with topic mine is 94 it has lsd spins 2nd easy with 19"s Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524962 Share on other sites More sharing options...
LUME Posted April 8, 2009 Share Posted April 8, 2009 nope no body kit starcorps with dish respray and pumped and rolled guards and stretched tyres... ive got tanabe sustec pro's hks castor tops in the front and spring rates are 8 on the front and 6 on the rear wish my car would spin second lol sawps Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4524975 Share on other sites More sharing options...
Line 3 Posted April 8, 2009 Share Posted April 8, 2009 i also got starcorps 18" by 8 and i have 235 tyres on it i was supprised it goes in second lol Link to comment https://www.sau.com.au/forums/topic/264495-r33-gts-na-93-model-lsd-or-single-spinner/#findComment-4525552 Share on other sites More sharing options...
