ok i just have two questions
1 i was looking down around the oil filter to day and i noticed a sensor that wasn't plugged into any thing,so i am just checking to see if its an after
market thing and doesn't need to be plugged in or if it should. Where the oil filter screws into the plate between the block, is where the sensor in question is, on the front side of the car, so if your standing above its on your right side.
2 Down around the same area but on the transfer case there is a hose that connects to the front of the case and then comes up and is cut off it looks
like a breather hose, is that right
cheers
its a neo 25
https://www.sau.com.au/forums/topic/264882-couple-of-qustions/
Andy,
I don't know, but if it's not running too bad it can't be too detremental!
I'm sure one of the other guys will help you out, I've tried looking in my M35 engine bay but it's so chockers you can't see much :D
I should get around to having a good dig around but I'll probably unplug something lol
1. it is the oil pressure gauge sensor, for the R34's and manual stageas, prob cheaper for Nissan to leave it there.
2. yep, breather
thanks for you answers, mine is a manual so should it be plugged into something? sorry if these are stupid questions but the car is still new to me.
bis-e bee, yeah your right the car is running fine, so i shouldn't be poking around to much and just drive it. but i cant help it :banana:
i know what you mean.
i had a bunch of plugs just pluged into a blank plate next to the batt. no use to the car.
but think i was told their for super computers like Nissan or Tuners comps, plug straight in... i just left it at that haha
bis-e bee, yeah your right the car is running fine, so i shouldn't be poking around to much and just drive it. but i cant help it :D
It's extrange beeing a manual ,doesn't it have the three gauges in the centre console,so the oil pressure sender should be connected?BTW ,everybody pokes around imports ,allways trying to find some uprade(hmmm...freeby :P )
It's extrange beeing a manual ,doesn't it have the three gauges in the centre console,so the oil pressure sender should be connected?BTW ,everybody pokes around imports ,allways trying to find some uprade(hmmm...freeby :( )
Yeah it has the three gauges, boost volts and torque, no oil gauge
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
