Mechanically its great! I bought it off my moms partner who used it as a daily until he retired and got a smaller car with my mom and for 18 months it sat in the carport.
In the past 6 months i spent about 2500 on the engine itself and getting it where it is. All thats left to do is to replace the bushes within the next 6-8 months (as my mechanic says), but obviously sooner the better. i've been using it as my everyday car to work, gym, training - the usual- in the condition the car is in at the moment.
The car currently has:
Removed the airbag suspension, as they become costly to repair and replaced them with Bilsten shocks and springs - so you cant adjust height anymore (awww) - but handles AWESOMELY now!
Dual, cat-back exhaust
NGK platinum spark plugs, New leads and Coil packs.. which were all done recently (February 13 2009) and less than 2000kms on them (receipts)
we have repaired the wiring .. so all seats can be adjusted, bum warmers on drivers/passenger seat work, drivers seat is adjustable and now has 2 seat settings switch.
Rego until end of June.
$5500
Well, feel free to ask me more questions.
And call me if you want o432-8o8-254
https://www.sau.com.au/forums/topic/265498-act-1992-toyota-soarer-uzz31-v8/
wat are you lookin to trade mate? I got a 33 gtr plus cash my way
I'm looking for either cash or a straight swap with no cash adjustment.
looks good karl, hey in the ACT do you need to get a safety cert or similar done for transferr of rego into another owner?
Yeah a RWC (road worthy cert.) is required to transfer vehicle. I can provide one but you will need to transfer the rego within 14 days. After that it needs to be inspected again to get a RWC. Car has rego until 16/6/09.. so you could use that up before getting a rwc
Hmmmm... from the top of my head
The obvious vin/engine number check.. electrical (headlights, indicators, brakes etc..), not too low, not too loud, horn (i failed that once...). I had an rwc done when i transferred it to my name a month ago and it went through with no dramas.
EDIT: sorry.. did u mean outline what is needed on the soarer to pass the RWC? if so, then.. nothing. I did it a month ago and was in and out of there in 15 mins.. its complete stock except for the shocks, but they weren't phased.
Edited by S T A R 3 3
I can provide a rwc on request.. but as I said, the rego runs out in June.. and the RWC is valid for only 2 weeks until you need to get another one.
Price drop to $5200
A/C button starting to blink after 10-15 mins. Still blows cold air, but indicates that its on it's way and will need to be re-gassed. But to be certain, will need to run the A/C diagnostics.
The EMV is getting slow to turn on. Which means the backlight will need to be replaced.. any electronics store/electrician can have it cleaned and replaced (backlight, screen) for around 80-$120. It's been an intermittent problem where it would appear straight away on some occasions, but recently been abit slow and fuzzy to appear.. maybe due to the cold?
  • 3 weeks later...
Pretty keen to sell. $4500?
The good:
Bilsteins shocks
Engine is in great condition, and mechanically sound. Bushes is all thats left to fix.. but stil in driveable condition.
The Bad:
As per mechanic report - Play in frint upper control arm bushes, Radius rod bushes require attention, Rear dif bushes require replacing.
The niggling problems are aesthetic. Drivers door trim will need to be fixed, the handle is loose and will eventually snap. So at the moment, im closing the door by opening the window. Power windows work, but I was advised the motor (?) will burn out eventually or tracks to be regreased (slow to wind up). Front leather (ie seats, steering wheel and centre console) have usual wear and tear. EMV will need to be cleaned and backlight replaced. Any electronics repair shop will be able to do that and they have estimated around $70-120 for that. At the moment the EMV turns on and off intermittently and when there is no image, the options on the screen can still be pressed, but not seen.. you know?
The Ugly:
Well, feel free to ask me more questions. If you want more pictures of anything in particular, please ask, I'll be more than happy to take them.
And call me if you want 0432 808 254
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
