Renovating House And Would Like To Help Out Sau Tradies
Hey All,
well I am going to be doing some renovations on my house and need good reliable tradies and I thought seeming as there is such a big community on SAU and times are a bit tough I would ask here first incase anyone wants work.
I will need a sparky to install an IXL tastic and about 6 downlights and possibly sort out some 15amp power for my garage. not really a big job but can make is a weekend cash job if needed.
I will also be knocking down some small sections of wall, about 2 metres by 1 metre. I have been in the roof and am not sure if I will have to have reinforcements put in.
Also will be ripping up the carpet in the whole house and having the floor boards sanded and sealed
I will also be replacing the kitchen doors and bench.
so if you are a licensed tradie and are on sau and are interested let me know and send me a PM.
I am very handy and can help with any of the work. Also if you need any mechanical or tuning work done I can help you. we could do a sort of a trade.
Cheers!
i have a couple tradies mates that can help if u want ill ask them to call you
pm me ur details and ill ask them.
i know a painter, sparky and a plumber so tell which ones u want and ill call them tonight when i get home.
cheers
julz
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
