  • Replies 108
Posted Images
Cant we have a nsfw section, and make it CLEARLY marked that its nsfw? :D
Unfortunately never going to happen...being a family friendly public forum. Could try your luck in the General wasteland but someone always pushes the limits. The closest thing we get is prob when banana dan posts -> for scandyflick :)
lol Roo... I'm sure Tracey wouldn't mind you just volunteering her!!!!
Yeah ... I'd like to keep my nuts attached thanks :D
Maybe Tracy and I could both enter: her with the Stagea, and me with the Liana :)
you guy's are killing me, teasing me with talk of hot cars and women ,, my OPTUS wireless is so slow 900 byte speeds,(not kb),, I cant view the photos, I keep seeing the first 4 on nova's site grrrrrrr. (CSS code is wrong on the site too, makes it load slow as hell ,,,,doesnt help.)
someone post up the SAU girls photos on here and other hotties, at least , please..lol
farking optus 3G farce
excessive tats on chicks, why ? looks shite , not attractive at all !!!
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
