  • Replies 58
Still lots of great parts available. pm if interested!
Intake manifold assay $300
throttle body chambers $300
intake plenum $100 (*NOTE* will do deal if all three bought together)
R32 stock ECU $100
Stock RB26 cams (inlet and exhaust)$100 the pair
Rb26 head (valves,lifters,shims,cams,cam wheels) late R32 GTR $1200
4WD sump (no gears but windage tray incl.) $200
Stock turbo's (exhaust man, dumps,O2 sensors and piping incl.) $500 the pair
OS Giken twin plate clutch (3.81mm meat left on each clutch/no grooves) $600
Crank,rods and pistons(Late R32) $500 the lot
R33 centre grill (2PAK metallic silver) $60
R33 front bar (N1 look alike/ in black base coat) $150
Located in Adelaide and can organise shipping if needed, at buyers expense!
CAN VIEW PICS THIS LINK http://s621.photobucket.com/albums/tt298/huliengines6969/
Edited by huli
R32 stock ECU $100
CAMS SOLD- PENDING PAYMENT
Legit offers will be considered!
Edited by huli
Hey ilija , do you know if the r33 front bar would line up with m-spec side skirts ?
if you mean line up as in level looking(around car) then "NO" a inch or so would be the difference.
Edited by huli
do you have the bit thats between the throttles and the head and holds the injectors in??
The intake manifold assay is what I believe you are looking for! And yes I have one for sale for $300 and postage would be $60(extra)to New Zealand!
Edited by huli
***UPDATED LIST OF PARTS REMAINING*****
-INTAKE MANIFOLD $100
-tHROTTLE BODY'S AND ALL LINKAGES $300
-R32GTR ECU $100
-Rb26 GTR HEAD (INCLUDES CAMS,VALVES,SHIMS,LIFTERS,VALVES,CAM WHEELS AND HKS SPARK PLUGS) $1200
-GTR 4WD SUMP WITH WINDAGE TRAY (NO GEARS) $200
-STOCK TURBOS (INCLUDES EXH MANIFOLDS,DUMPS,O2 SENSORS,HEAT SHIELDS ETC) $500 THE PAIR
-OS GIKEN TWIN PLATE CLUTCH $600
-SET OF RODS AND PISTONS $200 THE SET
-R33 GTST CENTRE GRILL $60
-R33 FRONT BAR (N1 LOOK-A-LIKE) $150
-RB26 CAM WHEEL COVER (STOCK) $500
-TURBO INTAKE PIPING (INCLUDES TWIN RECIRCULATION VALVES) $250
POSTAGE AND HANDLING CAN BE ARRANGED AT BUYERS EXPENSE(FOR THOSE NOT SITUATED IN ADELAIDE)
ANY INTERESTS IN THE REMAINING PARTS. JUST PM ME!
-R32GTR ECU $100
Can you send me a pic of the N1 Front Bar? Would you post to Brisbane? if so how much for freight?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
