Suzuki Swift Gti
Bathurst Race Limited Edition Brame
Number 6 of 15
Wollongong NSW
80km South of Sydney
This Swift Gti is a rare model
It is in shmick condition, paint work is very good and still very glossy
Car is lowered on king springs sits very nice in the rear as you will see by the pictures,
Has painted black calipers front and rear
Black rims with chrome lip 17" tyres are 205/40R17 - $1100
5% tint on all windows looks tidy - $300
If you want the gold 15" simmons that the brame came with standard can get these for extra
black leather seats front and rear, as well as momo steering wheel, sparco gear shifter, leather cover around the shifter, momo badge in the centre console, strut brace in the front extractors as standard
The car runs like a dream with not one problem with it, engine is like new, brakes are almost new, tyres on the front are new, tyres on rear ok,
has remote central locking with emobilizer and siren very expensive $1000
NSW Rego Until November
Mods to the car include:
Air pod filter
Strut brace
Exhaust 2n1/4" NO cannon
Extractors
Sound System:
Sony mp3 cdplayer top of range
4 6"speakers
2 6x9s
1 amp
1 12"sub
(NOT THE STEREO IN PICS)
Basically selling as im now soon to be off my P's and looking for that TURBO
So as a price im not sure at all as I have spent HEAPS on this little pocket rocket but I do have to say a price ether way so
$9,000ono
Mostly after swaps for R32/33 S14 show what you got Rear Wheel and/or Turbo
yes cash adjustments ether way is acceptable
VERY good on fuel $40 to fill it up get 450km at tank so thats about 6.5litres to 100km
Call 0411241499
PM on here
[email protected]
https://www.sau.com.au/forums/topic/265942-fs-swift-gti-94-mint-cond-low-km/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
