i need a lower front passanger side control arm that will suit an r33 4 door rear wheel drive (awd may not fit)
i need it tomorrow if possible, earlier i nthe day the better.
PLEASE help me and heslo (as my car is sitting in his drive way taking up room :))
message or call me on 0401 38 77 26 if your able to hook me up!
thanks guys
https://www.sau.com.au/forums/topic/266075-need-urgently/
its all good steve, awd wouldnt fit. had a look around and pretty sure their different.
also, called u pull it and they didn't have anything. rang around heaps of places and only got through to JMS but they weren't open just had some guys in there working on their own stuff :P
BUT, got good news. i called George from GT Autosound and he's opening the shop for me later today if it doesnt get to late otherwise ill send the car down their monday.
either way, i have to to say that George has been a HUGE help and he's gone way far out of his way already!
cheers
https://www.sau.com.au/forums/topic/266075-need-urgently/#findComment-4542658
Big thanks to everyone that helped meout the past few days ;)
Heslo thanks for letting me dump it on your drive way much appreciated mate
Steve thanks for trying to see if the control arms are the same for me
GT Auto sound are awesome they opened up the workshop for me on a sunday and fixed it yesterday for me, got the car fixed just bent a control arm thank god and they also fixed the alarm too.
Lauren went and picked it up without telling me to surprise me last night i tell ya it put a huge smile on my face.
So shes (meaning the car) back on the road again. Thanks to everyone for trying to help me out :worship:
Much Appreciated
Kye
:P
Edited by Import S13
https://www.sau.com.au/forums/topic/266075-need-urgently/#findComment-4546403
hey mate
laurens grandma is coming over from the uk on fri so we are having tea and doing all the family BS lol
but after that we should be out and about it just depends on what time we get done eating
ill call u on fri though mate
https://www.sau.com.au/forums/topic/266075-need-urgently/#findComment-4549132
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
