i need a lower front passanger side control arm that will suit an r33 4 door rear wheel drive (awd may not fit)
i need it tomorrow if possible, earlier i nthe day the better.
PLEASE help me and heslo (as my car is sitting in his drive way taking up room :))
message or call me on 0401 38 77 26 if your able to hook me up!
thanks guys
https://www.sau.com.au/forums/topic/266075-need-urgently/
its all good steve, awd wouldnt fit. had a look around and pretty sure their different.
also, called u pull it and they didn't have anything. rang around heaps of places and only got through to JMS but they weren't open just had some guys in there working on their own stuff :P
BUT, got good news. i called George from GT Autosound and he's opening the shop for me later today if it doesnt get to late otherwise ill send the car down their monday.
either way, i have to to say that George has been a HUGE help and he's gone way far out of his way already!
cheers
https://www.sau.com.au/forums/topic/266075-need-urgently/#findComment-4542658
Big thanks to everyone that helped meout the past few days ;)
Heslo thanks for letting me dump it on your drive way much appreciated mate
Steve thanks for trying to see if the control arms are the same for me
GT Auto sound are awesome they opened up the workshop for me on a sunday and fixed it yesterday for me, got the car fixed just bent a control arm thank god and they also fixed the alarm too.
Lauren went and picked it up without telling me to surprise me last night i tell ya it put a huge smile on my face.
So shes (meaning the car) back on the road again. Thanks to everyone for trying to help me out :worship:
Much Appreciated
Kye
:P
Edited by Import S13
https://www.sau.com.au/forums/topic/266075-need-urgently/#findComment-4546403
hey mate
laurens grandma is coming over from the uk on fri so we are having tea and doing all the family BS lol
but after that we should be out and about it just depends on what time we get done eating
ill call u on fri though mate
https://www.sau.com.au/forums/topic/266075-need-urgently/#findComment-4549132
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
