My Car is off the road atm after the last time I went to Willowbank raceway which as I found out turned out to be a good thing as I might have found myself in a very dangerous situation driving anywhere.
I went to a drift night at Willowbank raceway and took my car out on the track for some fun. I did about 10 to 15 laps and noticed that everytime I went to full lock my steering would become very heavy. i didnt think anything bad of it at the time as i thought it was a HICAS issue. Inspecting the inside of my wheel i noticed there was a deep cut in the side wall of the tyre, a good 15-20cms long and it was several layers deep.
As Id spin out my steering was full lock and the added force of the car spinning and the wheels not being in the direction the car was travelling the tyre would rub up against the chassis and brake line mount and cut my tyre up
I have the same problem on the other side.
Now I went for a drive in my mates GTR and was diappointed at the steering turning circle on it, with my car doing a full "U" turn, in the GTR Id have to do a 3 point turn.
Now im just wondering if my steering rack has spacers inside it. Compared to other imports you can see there looks to be more lock.
post-58506-1240109205_thumb.jpg post-58506-1240109409_thumb.jpg post-58506-1240109524_thumb.jpg
Now what can I do? do I get different offset wheels, fit wheels spacers but being a street registered car will it comply with an engeering certificate, or would the rack be flogged out?
https://www.sau.com.au/forums/topic/266097-extra-steering-lock/
lower offset, i run rack spacers and every time i go back to stockies for whatever reason i get rail rub, simply because of the high offset. what rims are u running (width/dia/offset) and tyre size.
F 17x8.5 +38 offset with 215/45R17
R 17x7.5 +32 offset with 215/45R17
This is correct and suprised me as I thought I had 17x7.5 all round, but ive never had to change front tyres since I got the car.
Now correct me if im wrong, im still trying to understand offset, but the less the offset the more they stick out of the guards or from the hub?
Correct, Lower offset should push the outter edge out from the hub, I use this to work out what is what... http://marksink.com/tire_wheel_offset/offset.html
Putting your rear rims on the front and the fronts on the rear will give you 19mm more clearance on the inside.
yeh switch the front and rear around and u should be right, no guarentees as +32 is still fairly high, but should be enough.
and yeh, refer to this: http://www.skylinesaustralia.com/forums/Wh...de-t216654.html
regarding offset.
I switched the rims around. The rears look alot better with some of the tyre sticking out of the guard, if its goin to be an issue ill give it some camber.
As for the fronts it sits further away from the strut but it still looks like its goin to rub on the rail not as much as hitting the brake line bracket and tearing my tyre but still hitting that rail. Another thing is now the wheel sits more out there is more lock on the wheel and the tie rod now comes in contact with the lower suspension arm at full lock. When it does hits it, it moves that mounts for the caster rod, changing the suspension alignment. Is this goin to be an issue? I can post some pictures to make it easier to understand...
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
