LOL, here ya go ya chickens.
Hopefully we'll get a few posts in b4 Andrew stomps on this thread. :D
im with ben and steve!
make that +2
im going to watch port & the saints this friday night! hopefully we put up a good fight at home
yeah that's the key cause clearly the Saints are the most in-form team so far this year so I hope they don't blow us away......kicking long to the square does work as we proved on the weekend so why we don't always play like that frustrates me!! Lol, we've got Warren Gary & Lade who can take a good contested mark in a pack not to mention Jezalinko jnr :wacko: (what a screamer he took)!!
Even though the Cats have just gotten away with the 4 points in a couple of games so far this year, they'll finish above the Saints though......they just seem to have an extra gear that no other team has so I'm looking forward to seeing the Cats vs the Saints.
https://www.sau.com.au/forums/topic/266313-footy/
  • Replies 515
Posted Images
this should be in the wasteland guys.
nah
theres enuff love for the national game that it warrants its own thread else it risks cluttering up the wasteland with other shite. put it this way kral, this way u can actively avoid it and wont have to worry about footy talk in the wasteland
and yeh terry wallace is stuffed
-D
https://www.sau.com.au/forums/topic/266313-footy/#findComment-4545514
well you took your 2nd line out of my mouth.
Haven't seen the footage yet but apparently an umpire took one of our players out of the game but because he has to have a clear corridor behind him after a bounce, our player could burn for it :wacko:
https://www.sau.com.au/forums/topic/266313-footy/#findComment-4545587
Cheers for the edit, I've been sniffing too many paint fumes today!
Now the AFL is upset because an official complaint wasn't made and they're asking Collingwood for a please explain because it's been discussed in the media. I hate Collingwood with a passion, but I think good on ya because these bullshit rules are killing the game. Umpires need to be made accountable, just like players are to selection committee's.
Edited by TALBO
https://www.sau.com.au/forums/topic/266313-footy/#findComment-4545635
Cheers for the edit, I've been sniffing too may paint fumes today!
Collingwood are a universal constant
Theyre always obnoxious
Theyre always imbred imbeciles
Theyre universally loathed
Nobody likes them except themselves
sorry I got carried away and thought I was talking about port then..
bwahaha
-D
https://www.sau.com.au/forums/topic/266313-footy/#findComment-4545649
i didnt know these guys played footy too hmmmm might have to rethink watching a game might not be boring after all or :woot: a little gay watching guys run around in tight football shorts
Steves so homophobic he's afraid to throw his clothes in the closet :D
-D
https://www.sau.com.au/forums/topic/266313-footy/#findComment-4545713
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
