  • Replies 515
Posted Images
Collingwood are a universal constant
Theyre always obnoxious
Theyre always imbred imbeciles
Theyre universally loathed
Nobody likes them except themselves
sorry I got carried away and thought I was talking about port then..
bwahaha
-D
On that note ill say go my beloved pies.
Love being the most hated in the league
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4552010
Wallace has shown that he can at least coach (ie Doggie days) so what does it tell you about the mind set of the players??
Were they all hoping Cousins would do it single handed so therefore no need to have a good pre season??
Or do they suffer from the number 9 stigma (where they finish on the ladder each year - just out of the finals, for those that aren't AFL savvy) which has plagued them for years??
I don't think they should dump Wallace yet....leave it till at least mid season.
On the other hand, Harvey has not yet proven that he can coach and should've stayed as the Bombers assistant coach.
People (Vic & SA media) are looking at how bad Melbourne & Richmond are travelling but the real pretenders are Freo.....they tend to go unnoticed cause they're so far away.
Biggest under achievers for as long as I've been watching footy, and that incudes the dismal Fitzroy era!
Feel sorry for freo in some way but hey we need them in the comp to provide qauilty trades for the rest of us. Sorry freo supporters
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4552025
News is a couple of days old now but he's safe till at least Round 12.........pretty much what I thought would happen.
Struggling on a couple of tips....rest are easy enough.
Port vs Saints??
Blues vs Dogs??
Freo vs Sydney........at Scooby?????
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4553762
Port vs Saints?? That should be a good game, Port might just have just get over the line at home
Blues vs Dogs?? Another good game..... I think Carlton
Freo vs Sydney........at Scooby????? Sydney if I had to put money somewhere
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4553791
Great round of footy...2 wins from 2 visit's at aami cruising!! Hopefully we can keep that up! Essendon collingwood..What a game! Thought the bombers were gone for all money just proves the gut's of that team! Wait till lucas and lloyd are kicking goals again should be a good squad
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4556450
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
