  • Replies 515
Posted Images
Collingwood are a universal constant
Theyre always obnoxious
Theyre always imbred imbeciles
Theyre universally loathed
Nobody likes them except themselves
sorry I got carried away and thought I was talking about port then..
bwahaha
-D
On that note ill say go my beloved pies.
Love being the most hated in the league
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4552010
Wallace has shown that he can at least coach (ie Doggie days) so what does it tell you about the mind set of the players??
Were they all hoping Cousins would do it single handed so therefore no need to have a good pre season??
Or do they suffer from the number 9 stigma (where they finish on the ladder each year - just out of the finals, for those that aren't AFL savvy) which has plagued them for years??
I don't think they should dump Wallace yet....leave it till at least mid season.
On the other hand, Harvey has not yet proven that he can coach and should've stayed as the Bombers assistant coach.
People (Vic & SA media) are looking at how bad Melbourne & Richmond are travelling but the real pretenders are Freo.....they tend to go unnoticed cause they're so far away.
Biggest under achievers for as long as I've been watching footy, and that incudes the dismal Fitzroy era!
Feel sorry for freo in some way but hey we need them in the comp to provide qauilty trades for the rest of us. Sorry freo supporters
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4552025
News is a couple of days old now but he's safe till at least Round 12.........pretty much what I thought would happen.
Struggling on a couple of tips....rest are easy enough.
Port vs Saints??
Blues vs Dogs??
Freo vs Sydney........at Scooby?????
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4553762
Port vs Saints?? That should be a good game, Port might just have just get over the line at home
Blues vs Dogs?? Another good game..... I think Carlton
Freo vs Sydney........at Scooby????? Sydney if I had to put money somewhere
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4553791
Great round of footy...2 wins from 2 visit's at aami cruising!! Hopefully we can keep that up! Essendon collingwood..What a game! Thought the bombers were gone for all money just proves the gut's of that team! Wait till lucas and lloyd are kicking goals again should be a good squad
https://www.sau.com.au/forums/topic/266313-footy/page/4/#findComment-4556450
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
