What a slopply game in the wet from Port & Richmond at AAMI today.
Port swicthed off in parts of the third quarter, slowed play right down and lost intensity alowing Richmond to catch up :P The other problem was innacuracy. So many bloody behinds that should've been goals!
Hows Tredders, he really is in good form this year, saved our arse.
I was at the game in a front row of the northern grandstand area. not a very large attendance at AAMI, but in those last 10 minutes the crowd really got going as port closed in on Richmond. when Tredrea potted the winning goal in the last minute and quickly shifted back to defence grabbing the final mark to end the game, the roar of the crowd was amazing, sounded almost as if it were a packed stadium! very cool atmosphere
watched bits of the crows & lions game on TV last night too, the crows really have some work to do
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4600059
  • Replies 515
Posted Images
yeah, cost us the game last week (ie more scoring shots than opposition) and nearly the same this week.
He is an absolute legend.....playing some of the best footy of his career the old boy.
Watched it on TV and you're right, the roar would make anyone think that the stadium was packed.......was on the edge of my seat in the last few minutes and not only screaming the house down but scared the crap out of my poor kids.
watched it with my father in law (mad Cows Disease fan) and actually felt sorry for him......poor guy was seriously frustrated with the 4th term.
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4600122
well i had my best result in tipping this week, finally scored an 8! Unfortunately my boys lost, first time ive tipped against them this year. Were some good games this round and some absolute blowouts. I think next week might be a hard one for tipping.
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4600224
I think it's going to be a pretty long frustrating season for us crows supporters
Gonna be plenty of ups and downs i think. Good to see Tippett strong upfront, few rushed kicks resulted in points tho, he will learn tho.
8/8 here too :P with an adjusted margin of 5, just missed out on top tipper in my comp.
Farkin dream team, Chapman out, Wiggins out, Higgins out, Skipworth out, but im waiting for him to come back, hes a gun.
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4600836
holy crap shit! i got 8 again this week :P i didnt get 8 once last year, and my first 8 this year was last week and now again this week! Utterly shocked! Now i'll probly get 1 next week lol.
My boys cemented themselves abit more this week in the top 8, hopefully we can make the finals this year!........CArn the Bombers!!! :(
Edited by skylineguy19
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4613890
So are any of you guys playing Dream Team or Super Coach? I tried to get a SAUSA league last season but only had a few people interested. This year I entered in the BigFooty division 2 leagues but am doing shite in both - too many injuries to my squad. As for tipping I'm on 50/72 - not too bad but well down from the leaders.
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4616724
I tried to get an SAU league going for Dream Team, got a few people.
https://www.sau.com.au/forums/topic/266313-footy/page/9/#findComment-4616860
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
