  • Replies 515
Posted Images
The medias word is that hes gone.
Ports staff have said he isnt completely gone. Still in the mix.
Real good player, really dissapointed if he does leave. going gets alittle tough he leaves it seems. I dont know all the details tho
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4827897
I love the guy and don't want him gone but I've heard that if a deal isn't struck with the Hawks and anyone gets in his way, he'll happily go into the draught which would result in the Dees picking him up.......only prob there is that they wouldn't be able to afford him.
If we lose him in the same way we lost Nick Stevens (who went on to get 3 wooden spoons and is now a "has been") and get nothing for him, I'll be the one in the front row of AAMI next season flaming him!
When he 1st came to our club he lived in his brother's shadow.....remember?
Brendan Lade made him the brilliant player he is today!!
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4828153
sounds to me like the going got to tough. Might be upset about his brother leaving "? being told to retire ?
Honestly. If this is the reason I really think its kinda weak. If he leaves a team for any of the above reasons he isnt a true team player.
I very much doubt the chasing a premiership theory. If this were the case half the AFLs bottom sides would be changing teams each year.
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4828764
Soooooooooooooo
Bigger weekend this weekend....Saints to knock off the bulldogs and geelong to beat collingwood?? Why do i have this strange and weird feeling that collingwoods going to knock off geelong....Hrmmmm
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4831110
Shane i feel exactly the same, I think St Kilda will do it comfortably over the Bullies, but Collingwood might just pull off a win :banana:
tbh I really hope the doggies get their premiership - has been a loooooong time between drinks for those chaps
-D
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4831341
-D
And you don't think 40 odd years is long enough for us????
Edited by Boof
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4831366
its been well over 40 years since the dogs got a premiership iirc lol
edit - thanks to damos link, it shows footscray winning in 1954 :) thats 55 years hehe
-D
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4831641
here are a few big names who could be/are looking for a new club:
Shaun Burgoyne, Matthew Lloyd, Shane Tuck, Nathan Brown, Mark Coughlan, Josh Gibson, Andrew Lovett, Barry Hall, Brian Lake and Mark Seaby.
some huge names! you could make half a new team with them. hmm, Gold Coast :) ?
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4831847
I think I'm going to be a Cats supporter for the next week
Agreed - Never much liked the saints (never disliked them either) but I owe Geelong my thanks for taking collingwood out of the running.
thank allah for that
-D
https://www.sau.com.au/forums/topic/266313-footy/page/24/#findComment-4836610
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
