Whats "crystallite"?
Because my headlights are FIlthy and have moisture in them.
Check it out on the web
Its a coating thats legal
you can have any choice of colours or black like I did.
No pics yet.....sorry.
There in Perth.
Guys name is Glenn
0428314005
https://www.sau.com.au/forums/topic/266376-crystallite/#findComment-4546717
lol..
Mike, i heard womens black stocking also work and can be taken off in a split second.
Might wanna give that a go.
tinting a headlight/tailight is illegal.
but yes the black stocking works a treat and can be remove easy if a cop pulls you over.
i find it hard to believe this stuff is ADR approved and if i remember correctly there was a topic in the main section of the forum about it
https://www.sau.com.au/forums/topic/266376-crystallite/#findComment-4547227
If he states it is ADR approved and it is not he is up for huge fines so i dont think it would state that unless it is.
By the sounds of the stuff it remains clear which is different to see through, clear would be ADR approved. Clear as in no bubbles or lines to dillute or stray light beams.
https://www.sau.com.au/forums/topic/266376-crystallite/#findComment-4547345
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
