Hey
I am selling my HKS Electronical Boost Gauge.(60mm)
Gauge is in bar form and reads up to 2.0.
Gauge has WAR/RST Button and Select Button.
Comes with cords/wires but they are still in my car will remove soon. Sorry for the bad pics but my camera is crap, but gauge reads like this from left to right - 600,400,200,0,0.5,1.0,1.5.20
Gauge is in great condition with no marks on the face, backing is covered in carbon fibre look contact and also comes with gauge dash holder thingy. Been told this is a very good boost and worth a fair bit new.
Looking for serious reasonable offers only please, this is a good gauge and its electronical aswell, so please not stupid offers.
Thanks
M3M3NT:burnout:
https://www.sau.com.au/forums/topic/26685-fs-hks-boost-gauge/
what are the wiring loop looks like? I have 60mm black face HKS ext temp gauge, it comes with piggy back loop to hook another gauge's ign, power and ground..just wondering they are same serial, so i can hook them up together..
any chance for you to take pic of the back?
Seeing its a very good one and electronical, ive been told i could get around $200 for it, so I am looking around that but I am open to offers as i would like a quick sale if i can get one.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
