TE37 in white.
18x8.5 +35 18x9.5 +35
95% front 235/40/18
80%rear 235/40/18
$2200
rb25det PFC
with HC
$1200
apexi AX53B70 turbo
EXC condition (SOLID turbo)
with elbow and braided lines
$1500
Z32 AFM with plug
$250
nismo 555cc injectors x6
flowed at 547cc +-5cc
$700
all still on car which doesnt go anywhere..
pics can be taken on request.
0433290801, [email protected]
https://www.sau.com.au/forums/topic/266851-te37-555cc-pfc-z32-apexi-turbo/
Hey Adrian what kind of power did you make with that turbo on your 25??
Edit: you answered that just before i posted :/
do you know what kind if boost levels it can handle safely???
Edited by /2on
  • 4 weeks later...
