I've got an 044 and it's very quiet, except sometimes it makes weird noises when the fuel level drops below the pump. I put it down to it not being that secure in the tank mounting so it has a chance to resonate a bit when in the air. One of these days I will pull it out again and put it back in properly!
I've heard from a couple of people that even the 044 is a quieter pump than a GTR pump, so I wouldn't be overly worried if the GTR pump is noisy.
Originally posted by firebladejr
benm.. where did you get that price? It seems quite good considering it's installed as well! Did you have to leave the car there overnight or was it just a day job?
Just my regular mechanic. He said it was a piss fight to do but well it got done and its working fine so its all good. I left my car there all day while I was at work but i believe it was about a 1.5-2hr job.
SLY33, it probably depends on the mounting. They have to modify the bracket to get it to fit so depending on what they did it probably affects the noise. I just bent mine back and to the right to get mine to fit, and this has probably helped.
Also if it's in a surge tank it will be noisy-as because most of the noise insulation comes from the fuel tank when mounted internally. Mine is only quiet because it's muffled by the tank.
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
