Greedy, Plazmaman, Hks, Cooling-pro Etc Need Cooler Asap
hi guys...
i need some advice from ppl who knows most about intercoolers, i needed to get one ASAP as i cant boost my car unless i have a bigger FMIC on my R34 GTT..
Greedy, plazmaman, HKS, Nismo, etc. whats the best one to get and easiest to install??
im not goin to run my car over 260 rwkw... so intercoolers that can handle between 250-260 rwkw would be fine..
and whats the difference between Bar and Plate or Tube and Fin? which is better??
my budget is around $600-700 for full intercooler kit with pipes including...
any advice???
thanx guys...
any shop from melbourne where i can check some intercoolers??
I'm running a HDi (Hybrid) intercooler which will handle more power than I am going to throw at it. I reckon they're in your price range. I've had no problems at all, but there's not much that go wrong anyway.
I can't remember if the stock IC handles 250kw or not, but I think it should take your power levels. It will deal with a bit more boost on the stock turbo no worries at least. FMIC's look good so why not do it anyway ey. They are defectable when used with a POD or if the IC piping is cored through a structural section of body work though.
I believe that bar and plate intercoolers have lower pressure drop when compared to tube and fin of the same specs. Tube and fin intercoolers overcome this by adding more rows and/or increasing the row size. I think generally tube and fin come out on top because they flow better inside and out when they increase the specs. I am not 100% sure about this but that's my understanding.
"I'm running a HDi (Hybrid) intercooler which will handle more power than I am going to throw at it." <--- Hybrid intercooler apparently are a lot harder to find, i read in some forums..and a lot of hybrid fakes claiming as well..so how would i knw which one is legit??
"I can't remember if the stock IC handles 250kw or not, but I think it should take your power levels." <--- stock SMIC apparently not safe to do, after a 2-3 rounds of full dyno and upping the boost the pipes and IC itself will go red hot and will cause a lot of problem, thats why i have to change my stockies coz originally i wanted to leave the stock smic and boost my car up with my new Greedy Profec B-spec II EBC...
They are defectable when used with a POD or if the IC piping is cored through a structural section of body work though. <---i know, i have POD at the moment, the only reason why i went POD like is bcoz i thought i didnt have to change my stock IC, but i didnt know i have to change it once i start upping the boost...but i will just have to find a way now how to get away with it..ive spoken to a tuner who can help me with the POD thingy issue...
700, trust kit, access autoworks, trade place vermont, sponser on here
thanx ryan,
i know access autoworks...i went there and got my STRI boost gauge and my Greedy Profec b-spec II..
i dont think they sell $700 trust kit for R34 GTT as i checked it on their website...
pic below is Greddy Trust Spec R HG Intercooler GTT R34 Skyline
Price: $2,400.00
Edited by myRB25DETT
i m still usin a stock intercooler on my r32gtr, have a hks r-type along the way. cuttently, i m pullin 320Kw on 1.8bar boost. no probs. for the pod issue, just custom a box arnd it. or go arc if yur feelin rich! haha
Edited by ujin
youll find pretty much any is fine
GTR
hybrid
chinese brander
or jap brand
all just depends on price. your best bet is to goto a local workshop in your area and ask for a price for a FMIC supplied and fitted
i have no idea where you live so ill pick some workshops around melbourne
eas
dr drift
chasers
race pace
re customs
any of those should be able to supply and fit a decent FMIC for a decent price
and the core etc will be fine for your power levels
ujin, i think all skyline GTR's IC are more superior compare to GTsT's and GTT's...and yeh i do have a custom pod box around my pod...
thanx ryan,
Price: $2,400.00
check the sponser section on here, they used to be less, but exchange rate sucks http://www.skylinesaustralia.com/forums/Gr...le-t231161.html
hi guys...
any advice???
thanx guys...
How much boost you want to run?
You have a R34 GTT, the Side Mount Intercooler should be fine for just over 200 kW's.
As for Bar and Plate or Tube and Fin, I can't remember exactly but I read in one of my magazines that one is better for air flow and the other is better for cooling.
For example, air flow would be great for drag racing as you are only on the track for less than 10 (give or take a few seconds) on the track, while the intercooler for cooling would be better off for circuit, drift and rally racing as you are on the track for longer.
That's just off the top of my head from memory...
hi skyline, i only wanted to run 11 psi high boost...i have another topic at FORCED INDUCTION its inregards to stock SMIC handling a boost 11 psi...maybe you can shade some lights off for me..i didnt want to have 2 topics here as well..please check it out for me..
thanx
thanx
Yeah so you want to run 11 Psi (+0.7 Bar) which is what a GTR would run...
From memory GTS-T's / GTT's run about 7 Psi (+0.5 Bar)
Correct me if I am wrong...
You should be fine with your Standard SMIC, as that's what ppl with R32 and R33 GTS-T's can use (the R34 GTT) to upgrade to to run just over 200 kW's.
Best to get your Boost controller installed, at the same time run a dyno tune just to make sure.
RE Customs and Racepace (just to name a few garages) can do it for you.
youll be talking about aftermarket ECUs by that stage and as a safe bet id still get a FMIC. although its getting pretty cold these days so maybe you wont have a problem.
i went with a home brand intercooler which set me back 435bux (far out the good days wen the aussie $$$ was doing good) and now i regret it. im aiming for 300+ onwards and i wish i went with a proper made jap cooler. just the quality and efficiency allround is better.
you also need to make a decision on weather you wanna risk a defect. because if you dont youll need a return flow cooler. which narrows your choicees down even more.
youll also need to motify the front bar to fit any sort of FMIC unless you get a aftermarket bar.
ultimately it comes down to a few things, answer these quesitons and we can give you almost a spot on answer.
Budget (how much do you want to spend on a cooler)
ultimate Power Aim? (try to think if youll go after market turbo)
Willing to Risk Defects?
GL mate.......i remember when i 1st started with my skyline....haha the good days.....
Yeah sure.
So what's the limit for the SMIC before upgrading to FMIC on a R34 GTT?
As he does not want to go over 260 kW's...
He still can go FMIC but no intake mods... (Upgrade the panel filter inside the stock air box and he could get away with that...)
His budget is around $600 - $700, I would say that could buy you a very good intercooler.
Maybe upgrading to a GTR FMIC would help as they are good for over 300 kW's...
i went with a home brand intercooler which set me back 435bux (far out the good days wen the aussie $$ was doing good) and now i regret it. im aiming for 300+ onwards and i wish i went with a proper made jap cooler. just the quality and efficiency allround is better.
1.Budget (how much do you want to spend on a cooler) <--cooler $600-700 but have to be a good brand as well..
2.ultimate Power Aim? (try to think if youll go after market turbo) <--not considering getting an aftermarket turbo yet so would not go beyond 200 rwkw..not planning to upgrade turbos, not in a few yrs...its just a daily car for me for now...
3.Willing to Risk Defects? <--only if i have to change my SMIC..yes i would if given no choice...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
