Hey guys these injectors are off my brothers r33 GTR which has only done 55,000km. These are still in perfect condition have been flow tested with no leaks or cracks. Also comes with the standard r33 gtr rail.
Reason for selling: He is selling them due to upgrading to 850cc.
Located: Gold Coast
Price: $400 pickup. Will post a buyers expense.
Contact Details.: 0421 320 526
Dont have pictures, but can get if needed. Im sure you know what standard gtr 444cc injectors on a rail look like.
Cheers Darren
https://www.sau.com.au/forums/topic/267253-gtr-33-injectors/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
