QUOTE
The '5S' Carpark
Want to park closer to the action at the Drift Supercup on Sunday 24th May?
If you arrive in a;
Silvia,Soarer,Skyline,Supra or Sprinter
we will have someone strategically placed to direct you into the 5S Carpark.......directly behind the main grandstand. When it is full it is full so you will need to cruise up to Mallala early!
Does that include stags?????
  • Replies 137
I went in through the front and handed my free pass and they didnt know what the hell it was! lol but they took it anyways and got in free... didnt get directed to any "VIP" parking like it says on the form thing though.
Oh? Woops I must of missed that part on the sheet or something... they took it upon entry anyways so no idea.
And no cops at all on the drive there and back - no cameras no nothing. I was driving in cautiously expecting an "RBT" station to pop up any minute now. lol
were cos everywhere between city and bay though tonight. Think it was 6 cop cars within half hour floating around.
And yeah is Sunday for the parking cause i was hoping to have the 31 back to bring it up tomoro but no such luck so will up in the falcoon.
just a heads up... ill be at la la land this morning until 12ish. ill be meeting with ruby after this, hes given me permission to collect any sau sa voting forms etc u guys may have :) cheers.
Thanks Adam. This house is taking up alot of my time ... and I gotta set up for this bbq today. :)
was a good day out there today. Thankfully there wasnt too much rain so the track started drying off by mid arvo making for some more interesting battles.
For those who werent there.
1st. Luke Fink
2nd. Adam May
3rd. dont remember but it was between leigh pidwell and paul austin.
Congrats goes to Luke Broadbent, mate of mine in the matte black cefiro knocking off Jake Jones in the top 32 attle in pro class but was then knocked out by paul austin in top 16. Top effort mate!
And another big congrats to Chris Gobin, another mate in a campagne coloured r31 with blue bonnet, qualifying 4th in street class and making it through to the top 8 battles.
Today definately inspired me to get back out there, will be organising a pivate prac day again soon, maybe go to a couple of pracs if they going to be dry, back into comps next year i think but if im really happy with how the car feels i might do g1 rnd 3.
FANTASTIC day, was a great turnout despite the weather and plenty of great moments on track.
To the disgrace that is SAPOL, I have no words. People legitimately go to a track to use their cars, keeping it off the street yet they still find a reason to come and shit on it all. Thanks guys, glad you're keeping SA "safe"
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
