Had my rear quarter rust removed and resprayed at:
So Cool Customs Garage (also called Old Skool Kustom Paintwerx)
Unit 5, 63 Paramount Drive, Wangara 6065
Ross Houchen: 93026991
They don't take EFTPOS and I forgot how much I paid (was $300-400 I think) but the work was pretty good, I can't fault them.
evrything cost so much money, i need t pay for my tune and setup for profect b 2, do you think it would be okay to leave the rust for a coupel more weeks? its bugging me, and it has a slight hole, i doubt it could twist or something but you can feel that the metal is weak,
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
